  • 4 Replies
  • 3856 Views
jgerb
Have a brand new Arlo Go on the Arlo Mobile Network.
Everythign works with the iOs app.
When logging in using the arlo website/portal through a web browser on my windows computer (either Chrome or Edge) the same problem occurs.  Once I login for 1 second it lets me click on "Live" but then switches to say "Getting Status...".  It always stays on Getting Status when accessing through the web portal.  Only works through the app.  Please help.  Have already tried resetting the device through the web portal and also tried power cycling and removing the physical battery as well.
jgerb
Probelm has been identified as an overly protective Barracuda web filter.  Our IT edept has worked with Barracude to no avail and simply opening up the required ports doesn't work.  When I take my computer off of our office network and attempt to access the camera with my computer connected to my cell phone/hotspot (no barracude filter) everything works great.  Easy fix without completely reengineering our network infrastructure and security is to use a web-based virtual machine such as browserling.com to access my.arlo.com.  We used Windows 10 and Chrome version 56 and were able to access just fine.  Only issue is that the free browserling.com site only lets you access the virtual machine for 3 minutes at a time, then kicks you out.  Also the range of available resolutions is limited so the arlo image is a bit granulated/blurry but good enough for our specific purposes.  You can always signup for a paid browerling.com account which will allow high resolution and no time limit.  Also, FYI, doesn't appear that the audio feed is supported by browserling but again, for our specific purposes it is not needed. Not a great fix but a descent bandaid for now.
ShayneS
Have you tried contacting customer support regarding this issue? I have attached the link below for you - Arlo Tech Support
mjayling
FWIW, I'm seeing the exact same behavior.
ShayneS
@mjayling
Can you reboot the Arlo Go and test this again. Do you have the latest Arlo Mobile App 2.7.1 installed?
jgerb
  • 4 Replies
  • 3857 Views
