I have 8 Arlo Go cameras in various positions around a field. Two of them are always going offline. I've changed their positions, cleaned the sim cards, done factory resets, put them in the same positions as other cameras but still they go offline. Any suggestions would be most appreciated. Thank you.
Best answers
An update is now starting to roll out for Arlo Go users who experienced offline issues with their camera. We expect it to reach all Arlo Go cameras in the coming week. Users may need to reboot (remove/re-insert the battery) and recharge the battery to receive the update, if your camera is already back online, no further interaction is necessary.
Additionally, we would like to clarify that this issue was not related to the 3G shutdown that has occurred on some carrier networks.Thanks for your patience and understanding. We'll continue to closely monitor your feedback to ensure your issue has been resolved.
Team Arlo -
Arlo is actively working with carriers to identify all the variables that could be contributing to this issue. It is a high priority for Arlo.
Thank you for the feedback & continued patience while we work to resolve this issue. We are actively working with our partner at AT&T to troubleshoot the situation.
Stupid question. How do I open a case file?
@ShayneS - We appreciate the update, but it contains little helpful content. Meanwhile our cameras have been unusable and unreliable for over two months, with the last update from Arlo many weeks ago. Understand that there may not be an easy simple solve, but any inofrmation regarding why the issue is happening and an estimated time for completion would be helpful. We are continuing to be charged by AT&T for our use of the cameras with greatly reduced functionality.
It is unacceptable that customers are contacting support as recently as this week and being told that that this is not a known issue. What do we need to do to get this escalated?
I have submitted a case to the Better Business Bureau, and would recommend that everyone else do this as well in addition to filing a case with Arlo and AT&T.
I would like to email the CEO and fill him in on this.
This has gone on way to long with the lack of support.
You can try Twitter - https://twitter.com/mbmcrae/
Can someone let us know how to Private Message the Moderator?
Thank You,
Thank you for your email and update. We are sorry for the delayed response.
We know what it feels like to be waiting for a resolution to a problem, and we're sorry we put you in that situation. We have tried sending a follow-up from the appropriate team, however, the team is still working on this issue.
Rest assured that we will provide an update as soon as we learn more.
Thank you for your understanding and patience as we work towards a resolution.
@K375 wrote:
Arlo is owned by Netgear.
No - that used to be the case. But Netgear divested Arlo back in 2018.
I sent an email to Customer Support. We will see how that turns out.
Something tells me, due to the lack of updates, we are one day going to get the "it can't be fixed, sorry guys" notification when they probably knew that all along. "Thanks for continuing to pay your subscription, we really appreciate it".
I'm about done myself.
@K375 wrote:
I was under the impression that Arlo is still owned by Netgear but they made Arlo a publicly traded portion on the NYSE.
NETGEAR no longer owns any shares of Arlo common stock is the relevant bit.
Thank you for sending your response and update. Upon checking your case, it seems that this is related to an ongoing issue. No worries, our team is already working on a solution for this. We will update you via email as soon as a resolution for this issue is available.
We are hoping for your continued patience and understanding.
@KBGood
Agreed, I will continue to provide updates as soon I hear more. Thanks for your patience.
Said they were trying to change something in the system where the cameras would only look for the LTE/4G cell signal since the problem was AT&T taking 3g offline.
I would rather them just go ahead and tell me it can’t be fixed. After this amount of time it doesn’t seem that it can be. Not only am I paying for something that doesn’t work, I have no security cameras at the same time. Just tell me and let me move on.
I think I would be less upset
We've not received any substantive updates other than that Arlo is working on it.
I specifically inquired on this forum last year if there was going to be an issue with the cameras with the move from 3G, but the responses I received from the community was that it would not be an issue and there was no response from Arlo. If Arlo is unable to resolve the issue, that's leaving a number of people with expensive cameras that Arlo rendered useless and obsolete overnight with no notification.
AT&T has confirmed they NO LONGER SUPPORT the Arlo Go camera.
Arlo's response has been that they are working with AT&T to resolve the issue. Not sure how that is happening if AT&T is no longer supporting.
There is no resolution. The camera for AT&T is no longer supported. I canceled my data plan and now have a useless, expensive camera. Arlo needs to offer everyone a replacement camera on a working network.
Modes et règles
