  • 10 Replies
  • 3843 Views
  • 5 In Conversation
jba32409
Request to have Arlo build a 12 volt adapter to charge cameras in very remote locations. Where the Solar panel is not applicable.
10 REPLIES 10
Very easy to do it yourself. Use a car USB charge adapter connected to a 12v battery. You can size the battery as you need.
RTW1
So I have a Arlo Go on a solar panel on ATT.  Its in a shady location and it gets cold here in Colorado.  The solar panel will not keep the Arlo charged so looking for options.  Your reply suggests the Arlo power is 12v DC and can be powered by any 12v USB charger.  Please confirm.
Arlo power is 5v. The idea is to use a 12v battery to power a USB charger to supply that 5v.
RTW1
So I see many solar chargers for cell phones.  Would one of those work - some of them are rated highly as to MAh.  Whats the MAh of the Arlo solar charger? If I can beat that might work.
MAh stands for Milliamp Hour - it's a measure of how much power a battery can store.  It doesn't apply to the Arlo solar panels, since they have no battery.
Well, the power supplied by the panel is likely rated in mAH so could be used to compare. I don't know the voltage or current rating of the Arlo panel - maybe someone else has tested.
That makes no sense.   It'd be like asking for the Watt Hour rating for your roof panels.  Watts makes sense, but not Watt Hours.
Power output in watts (or amps at a specific voltage) can be rated.  But you can't specify mAH for something that can't store power.
True - didn't think about the hours part. The output of any panel is some sort of amperage, not amp-hours. Mea culpa.
silveira
Previous answer is wrong. I've tried it. You can not charge an Arlo camera from a car charger as it does not provide the required min 9v of power.
A homebrew or commercial 9v power supply connected to the battery should work. 5v should run the camera but not charge it.
  • 10 Replies
  • 3844 Views
  • 5 In Conversation
