arlo go 2 LTE - VML2030 - mobile plans
Can you use any data only mobile plan for Arlo Go 2 as long as it uses AT&T 4G LTE network? When I contacted T-Mobile (my current provider), their monthly fees were too high to make this a camera a smart choice. May have to return it and start over. I was under the impression that it could use many 3rd party providers and not just AT&T or T-Mobile or Verizon. If anyone has other suggestions of what works for you, I'd appreciate it! A short-term pre-paid option would work as I really only need LTE service occasionally. Thank you.
It depends on your location, however this link should provide the information you are looking for.
https://kb.arlo.com/000062630/Arlo-Go-2-LTE-Wi-Fi-Security-Camera-FAQs
If you are located in the US these carriers work with the Arlo Go 2
- AT&T
- Cellcom
- T-Mobile
- U.S. Cellular
- Verizon Wireless
I’ve used Arlo go cameras for years and I’ve been waiting for the Arlo go 2 to be supported by AT&T. This has been extremely frustrating because there has been no reasonable information from Arlo. I finally bought one, got a SIM from AT&T and added it to my plan. it works perfectly. The problem is the service is extremely expensive. I have been connected to a company called Kore Wireless which offers IOT plans which seemed to be more economical. I will post again once I know more.
