Arlo Go 2 loosing signal
I changed SIM card carrier to other and now my camera keeps loosing connection with internet! Although service providers connection is good. I keep reseting and adding camera all over but 10min and again connection lost
If you move the camera to a different location does it stay connected?
If i move to different direction same problem. As i mentioned company which im using on my mobile phone same companys SIM i use in camera
Even if i move location its same problem( as i mentioned i dont have problems with SIM card signal because i use same provider on my phone)
Please contact support. Within the app on your mobile device click on the silhouette on the top left ~ support center ~ the device that you are needing assistance with then choose the behavior you are seeing.
