I have connected everything and am looking in correct library. I am overseas. Am given this 1st error but can’t see connection error as everything online and working except for access. Any ideas. Also can I use a vpn to access outside lan or do I need port forwarding? Thanks
You either need to set up port forwarding in the app and your router, or you need to deploy a home VPN in the router (assuming it has that feature).
The VPN approach definitely works with iOS. There have been issues reported with Android - Arlo released firmware to address that, but I think there still might be some Android users who are finding it doesn't work for them.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
