My original base station was not working so I bought a used one which I got to work but there’s no way to change the recording time from 10 seconds. I was able to make it longer with the previous base station, and I don’t think I can get a update anymore?
Have you looked at the camera rules in the mode(s) you are using?
if so, are you saying that the control for recording time
- isn't there
- is grayed out
- has no effect
- something else?
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
