  • 1 Reply
  • 1499 Views
petera313
My original base station was not working so I bought a used one which I got to work but there’s no way to change the recording time from 10 seconds. I was able to make it longer with the previous base station, and I don’t think I can get a update anymore?
Have you looked at the camera rules in the mode(s) you are using?
if so, are you saying that the control for recording time
  • isn't there
  • is grayed out
  • has no effect
  • something else?
