  • 4 Replies
  • 5315 Views
Zwaf
Dear all,
I'm aware that the Arlo Essentials run on battery power for prolonged periods of time and that they can be (re)charged using the USB port and supplied charger.
However, can I use the camera also while it is being charged? Or better said, can the camera also power and function when wired on AC-power? My question comes from that I want to place the camera in a hard-to-reach location (would require a ladder to remove for charging, but there is AC-power there)
amy_lynn1121
I have all of my cameras wired to be continuously charging. They are all out doors. They do just fine. I do however have them located in locations that rain cannot get on them.
dcfox1
Per the FAQ here the charger is for indoor use only and says to charge outside you can use the Solar Panel. I believe I saw you can not connect the essential directly to AC power at least outdoors but someone correct me if I am wrong. This link in FAQ can help.
How do I charge my Arlo Essential wire-free camera?
Zwaf
Should've clarified I was talking indoors. The hall has a high ceiling but there's AC wall outlets available. Obviously solar isn't an option indoors
dcfox1
Yea that makes a difference. On my Pro3 when charging inside it does still function as it should.
amy_lynn1121
