Car Alarm or Imobilisor interference
I would check on what frequency is used by the car. The dealer's service techs should be able to help. I tend to doubt that the car is the problem - I'd wager it doesn't use the 2.4GHz band.
However, interference is always a possibility as is signal strength. Since it doesn't happen all the time, it could be a neighbor's wireless devices. It could also be that the presence of the cars causes signal reflections, affecting how the camera connects. Hard to say without testing and maybe even some dedicated equipment that most folks don't have access to.
Is there a way to rearrange the cars for testing? How about moving the camera and/or router?
The indoor Ess cam only operates on 2.4ghz....
I would see if you can add a wifi extender closer so it is connected to a stronger signal then test with the car arming/disarming
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
