- English
- Cameras
- Re: Spotlight light not coming on when motion dete...
- 2
When manually turned on works fine.
Current settings in “Low Light Settings” is:
Spotlight ON;
Colour OFF;
Behaviour CONSTANT;
Brightness 50%
It is connected to a base station.
I’m wondering if it’s because I do not have an active subscription. HOWEVER reading the user manual, it states “The Essential Spotlight Camera and Essential XL Spotlight Camera include an integrated spotlight. This spotlight is set to automatically turn on when your camera detects motion at night.” KBs also indicate that motion should trigger the light to come on, it does not state that it has to be recording which is a feature of the subscription. It means the spotlight should work when motion is detected, however it doesn’t.
I’ve tried to reset it, tried removing and re-adding, I’ve also tried adding via wifi vs base station.
How do I fix this? Or is this a bug?
Hope this helps... So what they are saying is that you have to have a subscription to start recording to activate the spotlight, which is really dumb for security purposes like scaring the intruders with your spotlight...
Also my front doorbell stopped recording too....smh...
I wonder if we use(connect) local storage to activate the recording to see if that works? Has anyone tried this option yet?
That will work, but you need to connect the camera to a base station in order to get local storage.
I agree, totally annoying. I wanted a camera with a light to trigger so that I could see my steps when coming home (as well as recording any visitors). As soon as my free trial expired, the spotlight stopped triggering on!! If this is by design it is some shady business practice to ensure you subscribe??!!
Cloud recording requires a subscription, so you are no longer recording visitors.
The spotlight no longer comes on because the camera isn't recording at night. FWIW, personally I think there should be option to have the spotlight come on even if the camera isn't recording.
- 2
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
