Sound quality
Why is the playback sound on one of my Essential outdoor camera’s so poorly low even though I have speaker and microphone settings both set at 100%. The other essential camera is fine? Thanks
Clogman69,
Are both cameras the same model?
Yes, they are both the same cameras but yet one of them has poor sound volume.
Clogman69,
If you swap locations with the working camera. Does the issue follow the camera or the location?
It follows the camera.
Clogman69,
I encourage you to reach out to the Arlo Support team to investigate the issue further. You can find support options within the Arlo Secure mobile app under Settings > Support
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
