Arlo vmc2030 outdoor cameras. I bought these last year because my others got discontinued. Well called support today and they told I’d have to purchase another one. So I took it off my account took it down from its post. Water literally came out of the camera. Water , from shook it more water. So they aren’t outdoor nor waterproof. I can’t believe this!
And they won’t replace it. I bought 3 with solar charger
Where would I find that at on the little black sticker?
Inside the camera housing it will list "S/N" or in the Arlo app under the device settings/info
I had to take it off my Arlo feed because it was taking up space but hold on. Let me see if I can see the other number. Mine doesn’t open up mine has the built-in battery, but it does have is a little sticker that says open here
@Lilrara37 Whoops, sorry. You can find the S/N listed under the charger flap/cover.
There’s no s/number under the flap,but here’s two numbers that are on stickers
11451-21-14122
272-50113-01
Is this a VMC2030 Essential camera? Are you sure there isn't a 13 digit number under that flap next to the charging port?
Is it possible to install the camera again to your Arlo app?
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
