- English
- Cameras
- My essential wiFi spotlight camera will not connec...
My essential wiFi spotlight camera will not connect to my 2.4G router no matter what I do
My essential wiFi spotlight camera will not connect to my 2.4G router no matter what I do. Nor can I reset to factory settings.
What do you see when you try to either onboard or reset the camera? Are you holding the sync button for >15 seconds when resetting? Is the battery charged?
Testing all your comments. No it did not help.
But you didn't tell us what you see. We need all details.
Charged all night.
8:52 am. Steady blue light.
Set router to 2.4
Pressed sync 2 seconds
Flashed blue 5-6 times then stoppped
Pressed sync again
Flashing blue
Looking
Did not connect
Flashed amber
Pressed sync again
Flashing blue
Got chime
Stopped flashing blue
Pressed sync again
Flashing blue
Looking
9:00 am did not connect
Flashed amber 6-8 times
Now nothing. No lights
Regards
No personal details on an Internet forum, please.
The "no w no lights" is problematic. First, try a reset as described here:
https://kb.arlo.com/000062438/How-do-I-factory-reset-and-re-sync-my-Arlo-camera
If still no good/no lights, swap at the store or, if you have a subscription, use Settings, Support to start communication with official support.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
