I have 2 Arlo Essential XL Wire Free Spotlight 1080 security cams, 1 covering front door and 1 inside covering entrance and lounge. I have started doing the usual covid work from home. I work in a home office down the other end of the house. To save battery life I don’t want notifications every time I walk into camera range when im awake and at home, but I would like to be notified if someone else does if im out or asleep. What is the best combination of settings (schedule and geofencing possibly) to cover this situation?
Personally I'd leave the outdoor camera armed (unless you or maybe pets are moving into its frame of view a lot). Then schedule the indoor camera to be disarmed during your normal work hours.
Start by using geofencing during awake hours, and schedule the cameras to be armed when you are normally sleeping. You do this by having the geofencing "Away" mode be Armed, and it's Home mode as "Schedule".
One thing to be aware of - you can't schedule across midnight. You have to schedule the mode to end at 11:59, and then schedule it again to start at midnight.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
