Johntherealtor
I’m looking for the Arlo customer service phone number
help😕😕😕
117 REPLIES 117
JWBJR
I need their phone number about my bill, not my product.  How can I get a phone number?
Joseriky
  • Cancel my service
BrookeN
Can you please dm me a callback number as well as a good time to call. That way I can have support look into this further. You send a dm by clicking on the envelope icon on the top right of the forum page.If you don't see it, then go into your profile settings and select preferences, then "Private Messenger." Then select "Turn on private messages" if it is turned off.
sessr
Just like the rest of your website after you answer the questions it gets stuck on NEXT! I can't get help no matter how hard I try! I'm stupid for opening a yearly subscription with this company, thinking about going to my bank and disputing it.
I have a sub for multiple cameras and only one will register and work. The other is a wired floodlight that gets all the way to "find a strong network" and it doesn't find anything. Stupidly, I am instructed to put my MOUNTED floodlight that is WIRED into my home 5 feet from my wifi router that is in my living room? You're joking, right?
Next is the 2.4 ghz question which is easily answered because I already have 1 camera (Essential XL) successfully registered and working!
Frustrated and mad that I've wasted all this time and money!
sessr
no it doesn't!
BrookeN
@sessr I would be more than happy to have someone reach out to you and assist. Can you please dm me a callback number as well as a good time to call. That way I can have support look into this further. You send a dm by clicking on the envelope icon on the top right of the forum page.If you don't see it, then go into your profile settings and select preferences, then "Private Messenger." Then select "Turn on private messages" if it is turned off.
sessr
Thanks BrokeN but I've already tried to get a call back and I never got the call. I think I have it figured out though, obviously I have to either upgrade all my cameras to Pro5 or downgrade my Modem as it is not able to be adjusted to only 2.4ghz since it is dual band and not able to be programmed to shut down the 5.0 side of the bandwidth, or I can just cancel everything and go to another company.
It concerns me that the inability of your product to connect to the most common and reliable frequency that most new Modems use is not made readily available to people buying your product and I'm considering my options right now as to what I will do to rectify this bad situation. As I said before I paid for a year in advance, the multiple camera option so I'm $250 in the hole, not including the 3 useless cameras I have bought, only two of which I can and will be returning.
Right now I don't even have working flood lights in the rear of my home because your lights do not support 5.0 even though it is a NEW product. Now I'm not getting notifications and I can't multiple delete so I have hundreds of videos on my feed I don't want and the update they suggest to be able to delete more than one at a time is nowhere to be found. Just a million different things wrong with your product, the App and service.
Posas956
Looking for Arlo customer service phone number
BrookeN
@Posas956 what can I help you with?
Charris54
I need help connecting my other two cameras.
BrookeN
Which cameras are you needing help with @Charris54
rickzg1k
I just moved into a new house that has the Arlo system.
After reading all the comments and finding out you can NOT speak to a LIVE person, I threw everything in the trash and going with another company...
This is some BUUULLLLSHHHIIITTTTTT
BrookeN
@rickzg1k I could help you reach a live person if need be, you can also reach a live person from the app if there is a subscription. If you still have the devices I would be more than happy to help.
Davetil
Support center will not let me fill out the form to do chat because I don't have a device active.
I'm trying to connect my base station.
It will not connect to my router.
I just bought a new base and it still does not work.
A new thread of your own would be useful. Describe what you've tried and what you see, including LED behavior. All details are needed.
Sbarchie
My camera page has been taken over by your ad and I can’t get rid of it
BrookeN
On the app? Can you send a picture of what you are seeing please.
Woody4321
Haven’t logged in for a year. Trying but doesn’t accept email or password. Do we have to signup for a subscription and pay monthly?
BrookeN
To log into the account you do not have to have a subscription. Is there a way you used a different email address when setting up the account?
Woody4321
Repling to @ Brooke. Did I just get in?
BrookeN
I am not sure, were you able to log in?
rishiraj001
Hi,  am trying to cancel my Arlo subscription in UK, but no option within the App. Can you please help providing a contact number or how can I cancel? If I do not get any luck, I will stop my direct debit.
Rishi
BrookeN
Can you try doing it from my.arlo.com following these steps:
To cancel your plan on my.arlo.com:
  1. Log in to my.arlo.com.
  2. Click Secure > My Arlo Account.
  3. Click Cancel Subscription.
  4. Follow the on-screen instructions.
Retired_Member
Not applicable
I can not log into app. The verification is always expired when every time I tried to login.
BrookeN
@Retired_Member have you tried to verify the 2FA by a different method like email? Do you see the same behavior when doing it that way?
