Help with installing essential 2
Hi. I have purchased an Arlo base station and it is connected, but when I try to connect my Essential cameras, it first wants to perform an update. While it’s loading—where it says it may take a few minutes—the process stops.
I have switched to 2.4 GHz and turned off my VPN. How can I fix this?
I assume that the OP is talking about the firmware check on the base failing. Try rebooting the base to see if that helps.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
