The mobile app needs to always be running in the background for Geofencing to update location. Some mobile devices will turn off or close apps that are idle or unused for a period of time. Check to make sure your mobile device isn't automatically closing the Arlo app causing geofencing not to update.
I am having the exact same problem. It only goes into AWAY mode when I open the app. App is updated, Geofencing is set, location services is set to ALWAYS ON for the Arlo app, and Background App Refresh is on for Arlo. I just noticed that Background App Refresh was off for MAPS so maybe that was it?
Still doing it, wasnt the MAPS app
Iam having a iPhone 13. I also need to open the app.
Everything is turned on in on location and push notifications etc.
So this is a big error somewhere. A bug.
If you have IOS 15, that is the problem. Apple just released an update that fixes this. Install IOS 15.3.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
