- English
- Cameras
- Essential spotlight - no recordings on pro 2 hub?
I do not get a motion recording through a essential camera connected to my Pro 2 hub ? Any suggestions? Only the pro 2 cameras record.
No recordings to the cloud but you can record to the VMB4000 you listed when you set up local storage.
How do I set up local storage backups on a USB device using my Arlo base station?
Did your 3 month trial to Smart expire? If so you need a subscription for cloud recordings on newer cameras. The Pro2 would still be on the 7 day free plan. You can still have local recordings to Hub/Base depending on the model.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
