- English
- Cameras
- Re: Essential spotlight cameras won’t connect with...
Bought 3 pack of essential spotlight cameras. Have Starlink wifi. Have split the Starlink so have 2.4 GHz for Arlo use but the cameras cannot be found when try to connect. Have tried all the suggestions on Arlo support page and nothing works. Anyone else had this and sorted it out? Thanks
Message 1 of 6
3,674
5 REPLIES 5
Message 2 of 6
3,625
Yes I’m afraid so.
Message 3 of 6
3,614
Message 4 of 6
3,609
Thanks that’s really helpful of you but when I log onto the link I received from Arlo support it just says the case has been closed?
Message 5 of 6
3,550
I see what happened, I routed your case to the appropriate support team, someone will be reaching out again.
Thank you for your patience
Message 6 of 6
3,544
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
