  • 1103 Views
Wazade1947
I have 2 essential spot light cameras ( VMC2030) one works fine & the other has come up with "offline".
I have tried the batteries ,there OK, I have tried the amber light tip but it still does not work.
ANY FURTHER TIPS
That is confusing, as you cannot remove the batteries from the Essential cameras.
ANY FURTHER TIPS
Did you remove the camera from the account when you did the hardware reset?
Are you saying that you can install the camera, but it goes offline?  Or that you cannot install it?
Wazade1947
Thks 4 your reply
By batteries, I meant they were fully charged.
Trying to connect the camera after the bell response, it's just times out & won't connect.
Waz
ShayneS
