Any MODE created WITHOUT the camera in it turns OFF the camera ( disables same )
You have cameras A B C
So if you created a mode with cameras B C in it, then A is off
Truth2121,
Create a custom mode and only set up a rule for the camera you want to detect motion. Do not set up any rules for the other camera, this will mean that when this custom mode is active, the camera that doesn't have any rules associated with it will be "disarmed".
Truth2121,
You cannot create a mode that does nothing.
The active mode utilizes whatever rules you have created. So if you create only rules for cameras you want to record within the custom mode, no other cameras will be active. If you want no cameras to record, simply use the "disarmed" mode.
Ok, thank you. I will play with it some more and see if it works.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
