Reset is not working. Camera is blinking Blue for a view seconds.
Did you actually hold the button for at least the amount of time to get the LED blinking?
https://kb.arlo.com/000062438/How-do-I-factory-reset-and-re-sync-my-Arlo-camera
Hi, Its strange if I hold the button after 3 seconds, 1 second orange and then flashing blue every 3 seconds. With holding the button. The orange led 1 time only flashing 1 second.
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support through the Arlo Mobile App by navigating to Settings/System/Support.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
