Can't locate device onboarding
  • 1582 Views
irenehicks2753
I have the arlo essential spotlight security cameras and cannot locate device. The camera will chime from the QR code. My wifi is 2GEXT. Is this a difference from 2.4GHZs. If it’s a difference do I need to call my provider to have the router set to 2.4GHZs
No.
Are you seeing the camera in your router's attached device list?
irenehicks2753
No I’m not seeing the cameras in the router device list
OK.
A couple of things you can try:
  • double-check that the wifi security is WPA2 (AES).
  • If you have punctuation (dashes, spaces, etc) or accented characters in your network name or password, try removing them.
Do you know what wifi channel your router is using?
