  • 16 Replies
  • 6177 Views
Joepepperz
Hello like everyone else I cannot get HomeKit to find my cameras. Should be easy to locate and setup HomeKit but for some reason Arlo has made this a difficult process do I need a token reset
Joepepperz,
Unplug the power from your base station, plug back in and allow the base station to come back online. Then attempt to set up HomeKit using the instructions linked in my post above.
16 REPLIES 16
You need a base station for this feature - do you have one?
Joepepperz
Yes I have base vbm4000r3
OK.  If the essentials are connected to the base, you should be able to set it up.
Instructions are here: https://kb.arlo.com/000062279/How-do-I-connect-my-Arlo-device-to-Apple-HomeKit
If it fails, then post back and ask for a token reset.
Joepepperz
I have tried all the resets need token reset
Joepepperz
In Arlo app I choose HomeKit setup from base and it don’t discover anything
Joepepperz
Okay so what is next step please advise ???
Joepepperz
Hello @StephenB can I please get that reset thank you. Waiting patiently for a response
Joepepperz
I give up almost an hour now waiting to token reset to simply connect to HomeKit zero help here in community. I read other posts and people have had help and had token resets but I’m sitting here with no luck or help
Not something I can do - only Arlo folks can.
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Joepepperz
When I choose HomeKit from inside Arlo app don’t find any devices what is it that I’m missing here to locate the base I’m standing in front of it. Do I unplug the Ethernet cable to modem
Is your mobile device connected to the same network as your base station? Be sure you're following the instructions as they are listed here: https://kb.arlo.com/000062279/How-do-I-connect-my-Arlo-device-to-Apple-HomeKit
Joepepperz
Yes same network
Joepepperz,
Joepepperz
I unplugged it and waited then I go to HomeKit to discover devices and nothing
Joepepperz
Got it just discovered thank you James
