Can not set up the essential Spotlight camera
  • 1 Reply
  • 1646 Views
yitiewang
Press the sync button, and scan the QR code successfully with arlo iOS app, the indicator flash blue for several seconds then out, nothing happened next, I have tried almost 20 times with APP and web-portal, so frustrated
Did you select "Essential" with "Add device" or the "Essential Spotlight"?  If you select Essential, the onboarding for the Essential Spotlight will fail.
If you can disable 5 ghz wifi in your router, try doing that before onboarding (re-enabling it afterwards).
Also, make sure the app is allowed to use your local network (with iOS that's in the general phone settings - scroll down to the app there and select it)
