  • 11 Replies
  • 7109 Views
JKD24876
I recently added constant power to my Arlo Essential Spotlight cameras and found that while connected to power they constantly go offline and I have to manually reboot and connect the camera to the base station.  I have found that if I simply run them only on their batteries I do not have the problem.  Is running the cameras on constant power just simply not an option?
Best answers
  • JamesC
    JKD24876,
    No. However, there is a solar panel available for Arlo Essential cameras they may fit your needs. You  can find official Arlo accessories here: Arlo Accessories
  • JamesC
    JKD24876,
    We do not recommend that you use non-Arlo branded accessories with your Arlo cameras as this may cause damage or inconsistent behavior like you're experiencing here.
11 REPLIES 11
dcfox1
Are you using the charger outside? There is no AC outdoor power cord for the Essential, Just a Solar panel. It should still work while charging inside. The FAQ here say to bring the cam inside to charge. You may be though using an AC cord for another model that is the problem.
JKD24876
While plugged in cameras will run for a period of days and then inevitably will go offline.  If left unplugged to run on their batteries, the cameras work fine and remain online.
JKD24876,
How often has this happened? Are you able to easily and consistently reproduce the issue?
JKD24876
Yes, happens each time the camera is plugged into power.
JKD24876
All three cameras do this when connected to continuous power. I’m assuming they are not designed to do this or somehow it is the aftermarket outdoor rated power cable I’m using. Interesting how they’ll work for days before going offline.
JKD24876,
Are you using a third-party charging cable or an official Arlo branded charger?
JKD24876
Third party.
JKD24876
It does not appear that Arlo makes a weather rated charging cable for the Essential cameras.
JKD24876,
JKD24876
Does Arlo make an outdoor charging cord for the Essential cameras?
JKD24876,
