  • 7 Replies
  • 2576 Views
  • 5 In Conversation
MeadeEM
I'm trying to help my grandmother with setting up a camera she purchased in October 2022. I've followed the factory reset instructions, but no lights show up on the camera. When I try to contact support through the virtual assistant, it tells me that I'm not entitled to live agent support. I'm assuming this is because the camera hasn't ever been successfully added to the account. Is there another way to contact support, or anything else I can try to get this camera working?
ShayneS
I have escalated your case & someone from support will be reaching out to you as soon as possible. I have provided your escalations number here: 43476184
7 REPLIES 7
I'm tagging the mods ( @JamesC and @ShayneS ) so they can assist you in reaching support.
Phone support also requires a subscription (trial or paid), but in the case the camera should still be under warranty so she is entitled to get support.
She might still be able to exchange it with the seller (depending on where she purchased it).
ShayneS
Hi @MeadeEM
Are you still experiencing an issue installing your device?
MeadeEM
Thanks for checking in @ShayneS (and thanks for directing this @StephenB !).
Yes, I'm still experiencing an issue. I've tried leaving the camera plugged in overnight to charge, but it doesn't seem to make a difference. The camera gets warm while it's plugged in, but no lights show on the front at any point. I'm still unable to connect to the camera or perform a factory reset. I believe I was able to get the camera connected back in October, but it has since disappeared from the account.
ShayneS
MeadeEM
The situation has been resolved. Thank you for your help!
mboni15
Hello, I am having a similar problem. My camera indicated the batter was low so I brought it in to charge and it doesn’t show any lights while charging and it also gets warm. I’ve left it plugged in overnight with no change.
I'd be mildly concerned about the camera getting noticeably warm while charging. Of course, the exact level of warmth would be the issue with hot being real trouble.
In any event, use Settings, Support (Center) to select your camera model and start talking to official support for a possible RMA.
