- English
- Cameras
- Arlo wireless doorbell won’t ring second phone
I set up second account it has all p Permissions granted. Can get alerts on all cameras and doorbell. But when push doorbell button it will only call the first account. Any ideas what to try? I also tried removing and regranting permission too still same. And both are iPhones and settings are same on both.
Dotmar,
Take a look at the troubleshooting here: https://kb.arlo.com/000061950/Not-receiving-calls-when-the-Arlo-Doorbell-button-is-pressed-How-to-Tr...
After exhausting the options in the article listed above, do you still experience the same issue?
Hello,
Yes. Problem still exists. I turned off permission and back on and waited 24 hours incase there was a delay in system etc… still exists.
After farther troubleshooting was determined to be a os issue. Have to upgrade the second phone to newer model. Hopefully this helps others. Take care all
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
receipts
totally frustrated
VMC2030
VMC2030-100EUS
