- English
- Cameras
- Re: Arlo wireless doorbell won’t ring second phone
I set up second account it has all p Permissions granted. Can get alerts on all cameras and doorbell. But when push doorbell button it will only call the first account. Any ideas what to try? I also tried removing and regranting permission too still same. And both are iPhones and settings are same on both.
Dotmar,
Take a look at the troubleshooting here: https://kb.arlo.com/000061950/Not-receiving-calls-when-the-Arlo-Doorbell-button-is-pressed-How-to-Tr...
After exhausting the options in the article listed above, do you still experience the same issue?
Hello,
Yes. Problem still exists. I turned off permission and back on and waited 24 hours incase there was a delay in system etc… still exists.
After farther troubleshooting was determined to be a os issue. Have to upgrade the second phone to newer model. Hopefully this helps others. Take care all
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
