- English
- Cameras
- Arlo spotlight XL charging and connecting issues
Hi have a 1.5 year old Arlo Spotlight XL essential camera. It was working normal until recently I have had trouble charging it.
I charge it for half a day and the batt stays red. ( I have the latest firmware)
Today I decided to unpair it from my hub and now it won't sync and no light comes on when I try charge.
- the charger cord works for my other cameras. Surely this camera is not dead after 1.5 year????
Could be either the camera or battery. Does the camera work when connected to AC power? That would point to either the battery or charging circuitry. You can also try a different USB charger.
The charger was faulty and I have since managed to give it a full charge. Unfortunately nothing happens when I press the sync button. ( do not get blue flashing light, also camera not found)
Not sure what more I can do, what do you suggest
How long are you pressing it? The reset procedure requires about 15 seconds. https://kb.arlo.com/000062438/How-do-I-factory-reset-my-Arlo-wire-free-camera
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
