I bouth the VMB4500 Base Station but it just doesn't sync with the camera.
Have somebody had these issues?
Are the VMB4500 Base station and Arlo Essential Cameras Compatible?
Try removing everything from Settings, My Devices and start fresh. It may also be useful to press the hub's reset button until the LED starts flashing amber and let it reboot before claiming it again. Use the Sync button on the camera to do the same thing by holding it for >15 seconds until the LED flashes amber.
Yes it's compatible:
https://kb.arlo.com/000062284/Arlo-SmartHub-and-Base-Station-Compatibility
However, your process may need work. You first have to claim the base so it's in your account. Then you can sync the camera to the base but if the camera is already connected to your WiFi remove it from Settings, My Devices and then sync.
Thanks I tried removing the camera first and then sync again though the base station
but the base station just doesn't sync with the camera, it just like it just doesn't find the camera.
Could it be just be broken?
Thank you very much
it actually worked
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
