Arlo essential won’t sync
  • 2553 Views
VF-1
Hi camera won’t sync, done a hard reset already have another 2k camera working perfectly.
tried 2 different WiFi systems, still the same
Did you reset as this FAQ shows?
https://kb.arlo.com/000062880/How-do-I-factory-reset-and-re-sync-my-Arlo-camera-Arlo-Secure-4-0
If so, the camera may well be faulty so swap at the store.
VF-1
Hi carried out a hard reset several times, everything working up to the point where it chimes but it will not synchronise
Does your WiFi SSID or password have special characters or a space in them? If so, remove them or, if your router supports a guest network, enable that with a more bland configuration.
