So if I have both the spotlight and night vision toggle on in low light settings, I suppose the camera will use the spotlight rather than infrared when motion is detected at night? Or both? Should I turn infrared off if the spotlight toggle is on?
AFAICT, the two modes work independently. But I find that it ends up using just the spotlight in that case - the spotlight is bright enough to keep Nightvision off. It's ok to leave them both on, but it's also fine to disable the one you don't want to use.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
