I have a total of 5 cameras, however all 3 of my Arlo Essential Spotlight Cameras are no longer recording to the library. I get motion alerts but no longer records. I have reset my base to no avail. I cannot remove the battery in these however I can remove the plug for the solar panel charger.
I also made sure my library does not have any filters on, but only 2 cameras show in my library (my Arlo Pro 2) but I show all 5 cameras are synced to my base.
5 REPLIES 5
Do you have an active subscription for the Essential cams if your 3 month Trial expired?
No i no longer have a subscription. Didn’t know I needed one IOT have my events saved to the library. How are my Pro 2 still able to be seen in the library? Do I not need a subscription for those?
No just the cams newer then the Pro2's need a sub. It started with the Ultra in 2018.
So if I do not want a subscription can I just replace my essential spotlight cameras with Pro 2s?
Yes if you want but the Pro2 is hard to find.
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
