Arlo essential not charging
  • 2 Replies
  • 1367 Views
Kaospaven
Hi
I bought an arlo essential 3 pack and the doorbell.
for two of the cameras I am unable to charge then despite having used around 5 hours of time trying to get them to do so. for the one camera and doorbell there are no issues.
I have tried to change charging cables, power adaptors, removing and adding the device again, I have tried resyncing.
when the two not working cameras are plugged in they do emit the blue flashing lights and I can feel the power adaptor generating a little heat.
I am super frustrated by having to use some much time on something that should be plug n play - what to do?
Dannybear
Have you managed to add all three cameras to your account?
Charging batteries can take a long time if you’re using a low capacity adapter. Ideal adapter is a 5vdc 2A.
 If you’re relying on the arlo app to indicate battery capacity then compare with the arlo mobile app rather than the arlo web portal/website login as it has not working correctly for some.
Kaospaven
Faulty product - returned it - the store could not make it work either.
