Arlo camera can not be found in app
Any idea what could be the problem?
Might be fastest to just swap at the store.
Try rebooting the router. Who owns it - you or the ISP? If yours, have you made any security setting changes? Arlo also requires WPA2 to connect so be sure that's what you're using for your WiFi.
Any other idea ?
If you are adding the camera from your phone, try turning off mobile data. You could also try adding the camera from your PC web browser.
The bar code is telling the camera your home WiFi SSID and passphrase. If something is mis-typed, then the process will fail. It's also conceivable that there is a character in the SSID or passphrase that the camera isn't handling. You could also try setting up a guest network with a simpler passphrase, and see if that works.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
