Arlo Essential Spotlight Camera - Is it compatible with my Arlo Pro system/hub?
  • 1 Reply
  • 1717 Views
Retired_Member
Not applicable
Base station?
dcfox1
Base station?
Depends on the Base model. It won't for the VMB3000 series but will for newer ones. It also will connect directly to you home wifi without a base.   Here is a list.
What is the difference between each Arlo SmartHub and base station?
dcfox1
Base station?
