Arlo Essential Battery Life
  • 7 Replies
  • 4892 Views
  • 6 In Conversation
DearLiza
Recently purchased two cams. Both batteries are currently only lasting 1-2 DAYS, even on battery-saver mode with full wifi signal strength. Video does not record more than 5 min a day. What is going wrong?
7 REPLIES 7
Bring a camera close to the base/router to see if makes a difference.
you could also reset the cameras by using remove device and re-installing
test again
DearLiza,
This could be due to poor signal strength or interference. As suggested above, try bringing the camera close to your base/router  temporarily and test again to see if you experience the same behavior.
DearLiza
Thanks. I did bring both cameras closer to my Wifi router (no base stations with the Essential). It seemed to improve battery life fairly significantly, but I'm still seeing frequent drops in battery percentage from day to day. I'm thinking now it is due to my unstable Wifi and the cameras having to reconnect a few times throughout the day. Will keep everyone updated! Thanks!
How many total minutes per day of live viewing and recording are going on? If frequently >5 minutes per day that could explain the battery drop.
Constant123
What planet do you live on ?
dcfox1
I think you have to be on the earth to post.
