  • 10 Replies
  • 256 Views
Jenny2833
i need help understanding why i got no notifications when the fire happened and it magically went off after i went to sleep
If power went out to your router/Internet connection, there would be no ability to record anything. We simply can't explain anything that happened that may be related to a fire. Maybe the circuit that the router was plugged into overheated and started the fire? No way for us to tell but maybe the fire department could help.
BTW, smoke detectors likely would have awakened you much sooner.
10 REPLIES 10
We need a whole bunch more information to be able to help. All details help.
Jenny2833
my home burnt to the ground around 8 pm and i went to sleep at 4 the camera stops recording shortly after i fall askerp
Jenny2833
what more info it happen sept 25
Jenny2833
camera stops after 3ish 4 pm on sept 25 2025
Jenny2833
i need a solution bc other wise this seems like a lawsuit bc i would have died burnt alive had i not woke myself up
Jenny2833
it didn’t
Jenny2833
no bc the fire happen at my camper and the camera and router was 50 ft away at my house not burning
Jenny2833
this is your problem not the fire department
Note there are two methods used for fire detection.
  1. Audio Detection (listening for smoke detector chirps)
  2. Video Analysis (which is still in beta)
It sounds like your issue is with the second method (the one in beta).
The second method only kicks in when the camera triggers for motion (or sound).  Generally the cameras only detect motion about 20-25 feet away.
Did you get a recording during the fire?  If you didn't, then the cloud wouldn't have any video to analyze.
