can i configure -by some way- my camara Essencial 2k outdoor in Argentina?
  • 333 Views
Alexis23
i bought 2 essencial 2k cammeras in Amazon, but i cant configure in the app.
if it´s not possible, do you know when can we use it from latam?
thanks!
I'm not sure what you're asking but it seems you're in a country that may not have the ability to use the cameras yet. What country are you located in?
Alexis23
i´m from Argentina
Not all regions may be able to get support for the latest cameras. Additionally, Argentina is not on the list of countries that can have a subscription so it may not matter unless you also purchase a SmartHub so you can connect the cameras to that and use local recordings.
Right now, the only way to install the cameras would be to use a VPN to the US or other supported country to create a new account so you can add the cameras. Once set up, the VPN would not be needed.
