- English
- Cameras
- Arlo Essential Outdoor 2nd Gen
- Automation location and schedule trigger empty mot...
Automation location and schedule trigger empty motion events
Hello
i have routines based on location and schedule. When the system goes into arm away mode thanks to the routines it sends me a motion event for each of the cameras (VMC2050) at the specific moment they go into arm away mode. These events are useless and a bit polluting my feed for nothing … otherwise the rest is working fine
any idea ?
thanks for the help
Are you still seeing this same behavior?
Yes, it’s very annoying
The link below may be helpful to insure that those are set up correctly:
https://kb.arlo.com/000062777/About-Arlo-Routines-Modes-Rules-and-Automations
As well we this one:
https://kb.arlo.com/1085093/How-does-Arlo-Geofencing-work-and-how-do-I-set-it-up
it’s setup properly , the features are working fine and do what I want… except the bug that when geofencing enable the arm away mode , then right away, each camera record a 10sec motion. That’s creating one false positive per camera every time the Geo fencing enable the arm away mode…
You can see on the screenshot
I see what you are meaning now, that is interesting. Let me reach out to the development team, I will reach back out to you soon.
Although I suspect this is not the cause, just in case ...
Make sure the automations don't include an action for the cameras to record. Record actions are tagged as "motion" - no idea why.
No there is no action to record in the automation
@Jbg1809 can you please do a test automation. To do a test automation for the Leave Automation. Routines->Automations->Leave->Test Automation - this will change the mode to Arm Away. Let me know if it triggers a recording.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
