- English
- Cameras
- Arlo Essential Outdoor 2nd Gen
- can i configure -by some way- my camara Essencial ...
can i configure -by some way- my camara Essencial 2k outdoor in Argentina?
i bought 2 essencial 2k cammeras in Amazon, but i cant configure in the app.
if it´s not possible, do you know when can we use it from latam?
thanks!
I'm not sure what you're asking but it seems you're in a country that may not have the ability to use the cameras yet. What country are you located in?
i´m from Argentina
Not all regions may be able to get support for the latest cameras. Additionally, Argentina is not on the list of countries that can have a subscription so it may not matter unless you also purchase a SmartHub so you can connect the cameras to that and use local recordings.
Right now, the only way to install the cameras would be to use a VPN to the US or other supported country to create a new account so you can add the cameras. Once set up, the VPN would not be needed.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
