Automation location and schedule trigger empty motion events
  • 9 Replies
  • 1617 Views
Jbg1809
Hello
i have routines based on location and schedule. When the system goes into arm away mode thanks to the routines it sends me a motion event for each of the cameras (VMC2050) at the specific moment they go into arm away mode. These events are useless and a bit polluting my feed for nothing … otherwise the rest is working fine
any idea ?
thanks for the help
9 REPLIES 9
BrookeN
Are you still seeing this same behavior?
Jbg1809
Yes, it’s very annoying
BrookeN
Jbg1809
it’s setup properly , the features are working fine and do what I want… except the bug that when geofencing enable the arm away mode , then right away, each camera record a 10sec motion. That’s creating one false positive per camera every time the Geo fencing enable the arm away mode…
Jbg1809
You can see on the screenshot
BrookeN
I see what you are meaning now, that is interesting. Let me reach out to the development team, I will reach back out to you soon.
Although I suspect this is not the cause, just in case ...
Make sure the automations don't include an action for the cameras to record.  Record actions are tagged as "motion"  - no idea why.
Jbg1809
No there is no action to record in the automation
BrookeN
@Jbg1809 can you please do a test automation. To do a test automation for the Leave Automation. Routines->Automations->Leave->Test Automation - this will change the mode to Arm Away. Let me know if it triggers a recording.
