  • 5 Replies
  • 555 Views
JaMuller
Hi
I have a problem when the camera records, then the image just goes completely white but there is sound. While when I go into live images the images are perfectly fine.
Tried restarting
Swapped location with another camera
Turned off night vision
It's been like this for 2-3 months
5 REPLIES 5
Does this also happen when you make a manual recording while livestreaming?
Have you tried changing the brightness in the video settings?
JaMuller
When I record live video everything is fine, only applies when it records events.
Tried changing brightness without success
You could try removing the camera from your account, and then doing a factory reset.  You'd push down the pairing button on the top of the camera until the LED flashes amber (~15 sec), and then add the camera back to your account.
JaMuller
I've tried it and without success.
ShayneS
@JaMuller
I have escalated your case & someone from support will be reaching out to you as soon as possible.
