White pictures when its record
Hi
I have a problem when the camera records, then the image just goes completely white but there is sound. While when I go into live images the images are perfectly fine.
Tried restarting
Swapped location with another camera
Turned off night vision
It's been like this for 2-3 months
Does this also happen when you make a manual recording while livestreaming?
Have you tried changing the brightness in the video settings?
When I record live video everything is fine, only applies when it records events.
Tried changing brightness without success
You could try removing the camera from your account, and then doing a factory reset. You'd push down the pairing button on the top of the camera until the LED flashes amber (~15 sec), and then add the camera back to your account.
I've tried it and without success.
I have escalated your case & someone from support will be reaching out to you as soon as possible.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
