  • 21 Replies
  • 4552 Views
  • 2 Likes
  • 8 In Conversation
Millerngm
We have 3 outdoor essentials gen 2 hooked up, all running the same settings. One of them does not remain charged even when the camera says it is in full sun and charging the battery level is just dropping.
21 REPLIES 21
Try swapping the problem camera with one of the other two, and then see whether the problem moves with the location, or whether it stays with the camera.
Millerngm
I did try that with no success. I have also disabled the problem camera so it is not active but still connected to wifi and solar and the battery still drained. It doesn't even last 24 hours.
Millerngm,
From your description of the issue, it could be a hardware problem with the device. I encourage you to reach out to Arlo Support using the Arlo app under Settings > Support to further investigate the issue.
From there you can open a support ticket for that specific camera and an agent will reach out to you with more information.
MLinIdaho
I have the same problem: out of 3 cameras, one camera won't charge with the solar panel, no matter which solar panel I hook it up to. I fully charge it indoors and as soon as I hook it up to a solar panel, it starts to drain the battery. How do I get a replacement camera?
I don't want to get on the roof again to take the whole system down and then put a replacement system back up. I'll switch to a different brand if this becomes too much of a hassle.
MLinIdaho,
Millerngm
Thank you James, I attempted that this morning and was informed that my subscription does not cover live support. I will have to try to call someone or perhaps just return them to Costco.
Arlo secure subscriptions do include phone support, so something is off here.
Millerngm
They might include phone support but James had suggested using the app which requires you to chat which only allows you to chat with a bot unless you have a subscription with live support.
Are you logged in using a shared account or the admin account? From the admin account, the active subscription will be identified and you will be able to open a support ticket. If you're using the shared account, these options will not be present.
Millerngm
Thank you! I didn't realize I was using my login and the account is under my husbands credentials. I am now in a chat with support.
Millerngm
Quick update the support agent is requiring me to go through all the troubleshooting steps that I had already done prior to contacting them so they have it documented. It is quite frustrating as I have already spent 3 days swapping panels, charging with wall cables, and factory resetting this camera only to have to do it all again before any resolution can be reached.
The app has a phone support option in the support center.  However, you do need an Arlo Secure subscription to use it.
In any event, you do know how to reach them now.
MLinIdaho
I'm in the app in settings and there is no support tab to open. I don't see a way to open a support ticket ?????
Start by tapping on the profile icon in the upper left of the screen.  Instructions are here:
MLinIdaho
I followed the instruction in your link until it suggested clicking on the CONTACT tab, trouble is, there is no CONTACT tab on that page, only SUPPORT REQUESTS, COMMON TOPICS, COMMUNITY ARTICLES, and DETAILS.
Why is it so hard to get support with this product?? I just want a replacement camera to swap with the defective one!
I see "CONTACT" between "COMMUNITY ARTICLES" and "DETAILS"
Phone is grayed out because the US support isn't open yet.
I'm tagging the mods ( @BrookeN , @JamesC , @ShayneS ) as they can open a support ticket on your behalf.
Swirl3
Very frustrating I'm sure after you have approached to figure out the problem.  I have concluded the solar panels are at min design ability.  Any loss of a cell or direct sun will cause the system to not work.  I bought this as a kit from Costco.  I wish I could return and get the larger solar panels they should have packaged with these 2k essential cameras.  I would be happy to pay the difference if Arlo is listening.   Thanks
Squidziit
Any resolution on this yet?  I am having the same problem.  Charge camera to 100%, hook up solar panel, camera completely drains within two days.  I have 3 cameras on solar and only one is doing this.  The cameras are only about a month old and the solar panels are less than a week old.
Squidziit,
Aburgess
I have one camera that discharges completely in a few hours with little to no activity and has a solar charger attached. (Yes it’s in the sun) Typically once the camera gets to 70% it will go to 5% in less than 4 hours.
There have been other reports of solar panels causing the battery to deplete rapidly. Disconnect the panel, charge the battery and see what happens. You may need to exchange the panel or contact support for an exchange.
