  • 4 Replies
  • 3430 Views
truch
Should the Red LED glow be always on at night?
I only see colour video when I toggle visible white spotlight on.
Essential Outdoor Camera 2K (2nd Gen)
DannyBearAgain
The red LEDs are used for night vision, if you have the camera externally powered with continuous power the night vision LEDs remain active for the foresight feature else they Illuminate when motion is detected.
truch
I still have issues. Manual enabling 'Live' vision at night enables the two red LEDs which I would expect, but there is still no colour night vision.
I run on battery only but I would expect the night colour vision with the red IR LEDs.
Am I not understanding this correctly?
Thanks, Jeff
DannyBearAgain
The colour night vision is a false statement.
See below a previous thread about it.
https://community.arlo.com/t5/Arlo-Ultra/No-enhanced-color-night-vision/m-p/1676480
No.
Color recording after dark either requires the white spotlight to be turned on when motion is detected, or other illumination of the scene (for instance a floodlight).
The red IR lights are used for IR recording when there isn't enough visible light - which is rendered in black and white on the display.
This applies both when the camera is run on battery and connected to AC power.
