  • 7 Replies
  • 370 Views
Uteman
I just purchased a new essential 2k 2nd gen camera. It won’t connect to my VMB4000 base. The setup stops when the app says: searching for the device in our system. It will connect via WiFi, but I want to use the base. Any ideas on getting it to connect?
7 REPLIES 7
DannyBearAgain
I recall that the 2nd gen products were not connectable to the arlo Base/hubs when they were first sold.
An update was later released to allow them to connect but not sure if it was sent out to all Base/hub models.
Have you tried updating the base?
Also make sure you are not using a friend account.
Uteman
The base is fully updated. The camera description says it should work with my base.
Uteman
I dont think i am using a friend account. I only have one account and am not sure what a friend account is.
BrookeN
Were you able to get the Essential to onboard onto the account?
Uteman
I removed the base station from my account, reinstalled it, then the new camera paired to it.
BrookeN
Perfect! Thank you for the update, have a great day.
