Colour night vision issue
Hi there,
I have a new Arlo essential camera and have set the night vision to colour night vision but unfortunately when it's in live view at night it's in black and white unless I manually turn on my spotlight, does anybody know why this is happening and whether I can change the settings or ifbits a fault,
Any suggestions would be much appreciated
Have you checked the Light Settings in the camera settings?
Yes I have I spoke to Arlo and they said that the camera should be in black and white unless there is motion and then the spotlight comes on does anyone else have this same protocol?
When you livestream the camera at night, you need to turn on the spotlight manually.
When it detects motion, it will turn on the spotlight. Though the very beginning of the captured video might be black and white (actually infrared).
I'd like to know the answer to this too. I have 3 cameras and only 1 of them actually records in color at night...even though the spotlight comes on. It's very frustrating
Is it possible that the spotlight just can't provide enough light to illuminate the field of view?
Can you somehow temporarily add light to the area (turning on porch lights, etc)?
@Woody88 wrote:
Hi there,
Back to the original question (which may also be the second question, too), re-reading shows that it's all about live view. I do believe that by default the camera uses the IR LEDs and you have to manually turn on the spotlight, just as support said. There's no setting for this - what settings are available there are for motion detection.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
